Gunfighter97
If you've ever fixed something electrical on your IH and didn't test it till later, only to find you hooked it up backwards and had to take three or more things apart to fix it, go ahead and subscribe to this thread
Right, the beast is back now with 99.9999(thats four 9s!)% working electrics!
On to other things(thank God). I've managed to jimmy the signal switch fully working, what was happening was the contacts moved too far when signalling right and disconected both bright filament lines from the stop circuit instead of just the right. I put a ziptie around part of the switch to act as a shim and it corrected the problem. Unfortunately I'm a moron and didn't think to take a picture untill after I wrastled the steering wheel back on. Next note, I put in five gallons of gas from a can and the fuel gauge didn't move, however swapping in the gauge from the truck I stripped at the salvage yard showed just above empty. Am I correct in thinking something else may be wrong with this circuit(would think it would read atleast 1/4)? I have a home made continuity tester that I conected to the gauge and got the needle to come up on the gauge I removed so I'm unsure what may be happening. I'm celebrating the electric's completion (ironically with the 100th reply) via photo op. Really just a reality check on all the stuff I still need to do. Pics are of a couple areas I opened up/inspected for the first time out of curiosity, some of the non original components, some of things that I tried not to breath on for fear of breakage/turning to dust or lung disease, a couple of things I have no clue what to make of, and a small detail in the mounts of my winch bumper.
On another topic I want to become more familiar with the anatomy of the SV series engines, does anybody have cutaway pictures, or diagrams/exploded veiws? Am I right in my understanding that the cam drive in these engines is gear driven?(ie no "timing chain"?) I looked for play earlier today in the timing by rotating the engine slightly and watching for movement in the distributor rotor and found NO observable play whatsoever. Being that the previous owner said this engine had high hours thats great. I'm not familiar with this particular carb either, does the JB weld pictured apear to be over anything important? I kind of ignore that because inches away is the rustiest clutch slave cylinder I've ever seen. I will either be replacing this or ignoring it and hoping it goes away. My next set of fixes will be to run some rislone in the oil before changing to try and get the lifters of the two cylinders in the middle of the passenger bank to quiet down(also can somebody tell me how to reference cylinder # thanks in advance), VC gaskets, pan gasket, new filter and new oil. I may do a tuneup depending on if somebody out there with more experience thinks this distributor looks like it may need it inside (looks very clean/good to me)or maybe how to tell if it needs one? Also another question, is it worth buying a full engine gasket set rather than just the pan and VC gaskets? I may well go through the whole engine eventually.
A small detail I thought was quite cool was the IH logo on the bolts that mount the winch bumper to the frame(tells me it has been on there for a long @$$ time and also makes me want to rebuild the old winch). I noticed grooves worn into the front of the bumper where the winch spool looks like it may have cut into it. I hadn't tried to reinstall one of the winches I have for it, is there some kind if shim that needs to be infront and behind the winch? Hard rubber or just steel plate?
On the note of "tells me its been in there a long @$$ time" factory original parts, I removed.... Ehhemm, exhumed the mumified remains of my dash speaker (viewer discretion advised on those pics). Also I'm trying to determine the purpose of the plate steel inlay in the passenger side of the bed, its screws/nuts have been painted over so it hasnt been off for a long time... Any thoughts? Its on there so tight that I couldn't remove any screws when I tried last. (And yes I took the one picture with my head upside down)
Between big jobs I will tackle a bunch of smaller jobs like loostening up frozen cables and what not. Then just update in the next big post with a list to keep my thoughts collected.
Of all the real noticeable problems with this truck almost half were electrical, so its come a long way.
Credit to the forum for the library of info I used while wrenching, and special thanks to Scoutboy74 for his knowledge contributions. So enjoy an imaginary cold one and medium rare steak for now, this thing is off to a great start on its journey back to relatively good condition
if only there was another section in this forum for non IH vehicles
been reading into engine tech, seems like a mechanical version of my electrical spaghetti mess in that theres right around 10 wazillion causes and potential fixes for the problem. My problem is as follows: when I purchased the truck it didn't have this issue, it arrose a handfull of infrequent drives of various lengths after it sat in the local shop for 18 months give or take. It starts up with a noticable tick not real rapid, you can keep up with it tapping a finger not really even that fast. I developed what may have been an irrational fear of destroying my engine and since have not driven it on road and only ran it when I needed to. I had a frend who has worked with alot of engines look at it and he pinpointed it to cylinder #4 and #6 with an automotive stethoscope. I asked another even more experienced friend(previously mentioned when this guy tells me something I believe it without a doubt) he said to drain a quart of oil and add a quart of rislone, then drive it for an hour, then change oil. He also said I might take the cover off and make sure the valves aren't damaged or in need of adjustment. Well I took off the valve cover and boy-howdy are these valves big!(to be fair, the only ohv engine I've worked on was an inline 4 with about the same displacement as one cylinder of this truck) They also apear to be stamped steel with fittings staked in place. Any thoughts on what I should do/not do/look for? I pulled a quart of oil out today with a brake bleeder through the dip stick spout, have yet to put the rislone in, was just looking at the valve train scratching my head before I had to stop and furiously scrub oil off myself before an apointment. I read alot about people pulling the lifters out for cleaning, of course I've yet to get myself a service manual and am still a bit unfamiliar with the anatomy of/how to remove lifters from the 304. Oil btw reminded me of black coffey about the same consistency as reeeeally hot maple syrup(not real thin but not quite goop if that makes sence)
Steering on the otherhand, well.... My gauges (fuel, oil, and heat) cut out and came back on a minute later, the only thing it could be is the little do-dad where gauge power goes in back of temp, ill see if I can find one at napa. Engine sounded very unhappy for being left and not moved for so long... Cleared up after a minute or so, valve tick got better but still there. Have a feeling I should just go ahead and borrow the other truck for my IHPA pilgrimage. Next I've GOT to fix this steering....... Woohoo.... I like adrenaline but dang.....
