Scoutboy74
Moderator
If you're starting out from empty (tc & fluid pan drained) it will take roughly 9 qts give or take 1. May as well buy a 12 quart case. That way you have a few extreez on hand. Some people like to dump a few qts into the tc before installing it. I've never bothered with that step and I've never had a problem getting the level right. When I'm at the point where its time to add fluid and I know the thing is completely empty to begin with, I'll dump 7 qts down the fill tube, fire up the engine and let it warm up with the shifter in neutral. Always remember with a stock 727, the converter will not fill up with fluid while the shifter is in park. That's by design and that's why it says right on the dipstick and in the service manual to only check the fluid level while hot idling in neutral. With 7 qts in, I'm probably not going to see any fluid on the stick yet. Whether I do or don't its fine either way because I'm still adding. Dump another qt in, slowly cycle the shifter through each gear position and then back to neutral. Shove in the dipstick and take another peek. Now I'm probably seeing some fluid on the stick, but I'm probably not in the safe range yet. Once you have fluid registering a little ways up the dipstick, start thinking in terms of pints not quarts. Getting these units overfull is just as bad as not enough. You want the goldielocks approach. If I'm not in the safe range yet, I'm probably looking at 2 pints or 1 qt still to get it there. If I'm flirting with the bottom line, I probably will just dump half a bottle in which is 1 pt and check it again. Once I'm well within the safe range, its time to go for a short test ride and grab some gears. If all goes well, when I come back, I'll check the level one more time in neutral and figure out how many more pts, if at all I need to get that level up pretty close to the top Mark. I like to achieve and maintain a fluid level that is just a sliver below the top line. Anywhere within the safe range is...well, safe to operate, but I figure why flirt with running it too low? Give yourself some cushion.
