Mark Pietz
Took the day off to continue assembly. Took me half the day to fuss around and get #1 piston in (had to drive down the mountain to get a different ring compressor but ultimately needed both styles), but it's in. Used 0.006" feelers across the rod cap and torqued it down to 45 ft lbs. Piston and rod assy turn easily. Rod moves squarely back and forth that 0.006" on rod journal and piston pin, so that's a relief. Got the degree wheel in place and have re-established tdc; this evening will begin the degree process to see if it matches the grind sheet.
Interestingly (or maybe not so surprising), the deck isn't square to the top of the piston. Clearance on the intake side is about 0.006" and the outboard side is 0.003". I'll be checking each succeeding piston in turn just because.
By this weekend should have it almost done (except for the head) but still waiting on that arp stud.
Edit:
my degreeing skills aren't the best, but here are some numbers after toiling in the heat. I had some difficulty in getting my dial indicator stabilized. I also think my tdc is probably not better than within 1 degree
from sheet: intake @0.006" 9.78 btdc, I get 11, close is 64 abdc, I get 63;
@0.050,14.95 atdc, I get 15; close is 29.87, I get 29; @ 0.100 it's 30.64 atdc, I get 31, close is 13.04 abdc, I get 12; @ 0.200 it's 63.56, I get about 63.5; close is 2.18 bbdc, I get 4; 0.250 is 92.05 atdc, I get 91.5, close is 48.29 bbdc, I get 48.
Exhaust: 0.006 shows 56.68 bbdc, I get 57, close is 25.55 atdc, I get 25; 0.050 shows 32.57 bbdc, I get 33, close is 10.43, I get 10; 0.100 shows 16.65, I get 17, close shows 27.23, I get 28, 0.250 shows 38.86 abdc, I get 39, close shows 82.86 btdc, I get 84.
As I said, my "precision" with an angle bracket as marker and the cheap summit degree wheel (damn that thing isn't concentric!) leaves something to be desired - if I'm within 1-2 degrees I'd be impressed, but the key measurements seem about there. I can't get the centerline numbers to work and that's got to be a defect in my thinking, or maybe it's 100 degrees and I'm hot and tired.
Tomorrow I'll install the last three pistons.
Getting there!
Edit:
Getting there!
so I pulled that piston. If the outboard thrust surface is at 6 oclock, then is was around 7 oclock. It seems there was a burr on the top edge of the piston. I specifically felt round all the pistons for burrs (my fingers are only now recovering from the fine cuts), as I found a couple and dressed them off . But this one got by me. So I pulled out the fine file and a few quick swipes and the burr is gone. Damn!!!!
