Michael Mayben
not the good news that I was hoping for.I will mess with it some more tomorrow and hopefully can get the converter to engage with the pump. Otherwise I will just pull the tranny and wait for the $$ to get it rebuilt.
How much does a pump usually go for? And since that would need to be replaced I might as well have it freshened up and do the Jeep tailshaft conversion at the same time. Boy, the wife is going to hate me.
I have a few more used pump gear sets, unless the trans was heavily contaminated with water and set, there should be no corrosion inside the pump. I am getting short on gear rotors (part you will need) but those are available new for a very nominal price, they are manufactured as a "pressed metal" item (not a casting or machined unit).
You will also need the gasket and the perimeter square cut "o" ring for the pump housing, and a set of the neoprene-coated steel washers that are under each pump retaining bolt head. All those parts come in "soft parts" kit which also includes a new front seal for the torque converter hub.
You will also need to locate and account for the n=2 broken tangs from the pump rotor.
The inner and outer gears of all 727 pumps are the same for all year models, but the pump reaction shaft support and the input shafts are not interchangeable between "early" and "late" pumps/transmissions. I have posted a sticky regarding the differences.
For an idea of cost for doing this repair...we charge $105.00 for doing this with the tranny on the bench, including all parts.
We can do an entire B&M-spec Scout II tranny build including conversion to a Jeep d300-style output shaft for $995 with the customer furnishing the conversion shaft. That includes all parts and labor along with a vent relocation job. We occasionally have the Jeep shafts, one of ours will run $125 for the part, extra.
