Michael Mayben
Look careful inside the hub of the pump body...ya can see the bushing. That is a tri-metal type bushing, very similar to a full shell cam bearing in an engine. Steel backer, then a couplea layers of copper/babbit and a oilite bronze wear surface.
The bushing in t's tranny has been replaced fairly recently with an aftermarket item. That one has a wear surface that is "dimpled" for lube oil retention and appears to be perfect. So in this one instance, I'm not going to replace it. In normal tranny seal replacement, and of course during an overhaul procedure, this bushing would be replaced.
