T407/TF 727 DIY Reseal
thats about the best "webinar" I've ever attended.
I gather the innards of this beast are good for another 200k?
Sumbitch wuz beooteeful inside t! Except for the maladjusted bands. Whoever did that in the past used the specs for a much later version like a 46rh or sumthin', this one is just a plain old tf 727...no lockup torque converter system and notta od version.
Today the output shaft seals come out of the np 205 for yoke inspection and seal replacement. Dave sez the seals on those cases are problematic, he's gotta "fix" for that using a different seal system but we gotta know "which" size/bore the seal counterbore is for yore tc, he sez there are at least two variations.
The electrics have been stripped out and I've rigged a sealing cap for the speedo drive. But...I'm not sure if ya need the speed sensor for that injection control or not...isn't it a full mechanical injection setup on yore motor? No speed sensor needed???
Once all the dirty work is done, it's gonna git hung back on the hook and powerwashed so at least it don't stink likka diesel! But no paint per yore instructions!
sumbitch wuz beooteeful inside t! Except for the maladjusted bands. Whoever did that in the past used the specs for a much later version like a 46rh or sumthin', this one is just a plain old tf 727...no lockup torque converter system and notta od version.
Yep, pure mechanical injection! No electrics required to run, sept for the one wire to the fuel shut off. I had it running without the trans attached, in order to get some marvel oil into the injectors to preserve them!
Diesel stink? Thats pure perfume, buddy!
yep, pure mechanical injection! No electrics required to run, sept for the one wire to the fuel shut off. I had it running without the trans attached, in order to get some marvel oil into the injectors to preserve them!
Oookaay...consider the speedo drive to be sealed semi-permanent!
so I don't need to make some ultra trick bearings for this thing?
Only if we gut out the entire tranny for a build-up! Based upon yore work order we ain't doin' that now.
But...if ya kin git to work on all them plastic tapered rollers and loose rollers in that 205, we'll dam shore do one!
The input system to the transfer case on this setup is very different fromma sii married mashup. That's why it's got that dam longazz "adapter" piece that just adds to the tailhousing.
Finally got back to t's tranny package so I can get it finished and delivered to him before xmas!
Lottsa interest lately in how to deal with fluid leaks in the area of rotating components interfacing with an oil seal...transfer case input/output shafts, axle pinion seals, transmission output shaft, etc. So let's look at a typical output shaft seal service procedure.
The system we're dealing with here is a np 205 married transfer case bolted to the azzend of the tf 727 tranny. Very similar to what ya find inna stocker Scout II witha slushbox and d20. This dodge/cummins version uses a conventional "bolt-on" output yoke for the rear driveshaft, and a bolt-on front output shaft flange which interfaces with a cv joint. These of course are not "slip" yokes and are retained to their respective shafts through a spline system with nut.
Here's a pic of the package in "before" mode for reference.
After removing both front and rear output yokes and seal/bearing retainers (those are cast aluminum in this case), the parts are cleaned and readied for inspection. We're looking for any cracks or distortion in the retainers, stripped bolt or hole threads, etc. The old retainer gaskets are also scrapped/removed from transfer case and the bearings inspected.
Once the front cv joint coupling was cleaned, the reason for fluid leakage from that point was real obvious! Notice the groove worn into the machined surface, that was caused by grit embedding in the seal interface and turning to lapping compound when mixed with a bit of gear lube! If ya just install a new seal here, it will quickly fail and the leak will return in short order. So we either need to replace the coupling witha new one...or fix it!
This is a budget buildup...so we're gonna fix it using a common shop technique used with engines, transmissions, etc. That have this same condition.
If you can see a discoloration of the machined surface but not feel it with your fingernail, then cleaning the surface and replacing the seal will work. If any groove or wear can be felt, then that surface must be delt with.
Here's the service part we use to repair damaged rotating components when possible. It's generically known as a "speedi-sleeve" from skf or a "redi-sleeve" from national/federal mogul.
skf | about us
A very thin stainless steel "bushing" with a highly refined surface finish that replicates the oem shaft/journal finish. These devices are pressed over a rotating machined surface after cleaning and prep. Full instructions are enclosed with each part, and they include a installation tool.
While not an inexpensive part, they are capable of salvaging a component which otherwise could cost hundreds of dollars to deal with in any other manner. Typical cost is $18>$40 depending upon size and location where it's to be used.
These items are designed for a range of shaft/journal dimensions, so ya gotta measure your damaged part at several points and determine if it's a candidate for repair. Then the appropriate part is selected for installation. So it's a must that you either have a micrometer or caliper for measurement, or have a pro perform the inspection/selection process for ya. In this case, the flange journal measured 1.878" nominal which is right at the top of the tolerance that this part selected can deal with.
The steel "cup" included with the repair sleeve is the installation tool. It's sized to push on the flange on the sleeve and then a hammer is used to force the sleeve into installed position.
I use an anerobic locking compound ("loctite") to both lubricate the journal during installation, and to seal the inner gap between the journal and id of the sleeve. This is an interference fit, so some force is needed to seat the sleeve over the journal. The loctite prevents fluid migration through that "gap" in the long term.
Here's the sleeve with the tool engaged, and thread locker slathered on the journal. Simply whack it with a hammer until the repair sleeve is in proper position and then stop!!!
In this case, the sleeve could be whacked all the way to the end of the journal. That put the center area of the sleeve right in the sweet spot for contact with the replacement dual oil seals we're gonna install.
In some applications, that "flange" is removed from the sleeve after it's installed. That area is scored/undercut and a pair of needle-nose or dikes are used to perform surgery and snap it off and discard the waste. That's not needed in this case so the flange can be left in place.
At this point, the drive flange is now repaired and is ready for re-install. Cost for that redi-sleeve was $21...cost for a new coupling...$38>$49 depending upon source.
Here's a shot of the rear output yoke, this one is perfectly acceptable for re-use with a replacement seal system.
Now let's look at the seal replacement deal. First, the front output bearing/seal retainer seal "set". This is the are which was heavily leaking due to the damaged cv joint coupling that we just fixed.
The retainers/seals/output shafts, etc. On a NP205 can vary somewhat from version-to-version, same as for the type/size of coupling being used on the outputs. So this is for this particular dodge app, I'm not providing p/n for the seals, etc. Since what will vary with application! That is why ya must inspect what ya got first before obtaining the service parts! So much of what we deal with in the IH world has been juryrigged and infected with po virus, there is no telling what part you May actually need unless ya know it's original and what the transfer case came from!
This 205 was oem with a single seal used in the front output retainer. An "upgrade" that can prevent the damage we saw in the coupling, and greatly enhance service life of that area regarding oil leakage, is to install two seals, that are thinner in case thickness. And we're gonna slam one of 'em in backwards!
Common lip seals such as those shown have a single lip that is installed with the lip pointing at the "wet" side of the application. So we are gonna knock in one of the thinner seals just like it was an oem item. The retainer has a counterbore machined in, so that first seal is gonna git knocked in all the way until it stops.
Here's the first seal installed, this is the one that will keep lube inside (hopefully!) the case.
The duplicate seal will then be installed upside down and knocked in until there is a slight space between the seal cases, do not knock it in until it won't move any more!!!!! We want some space between the seals in case we need to "adjust" it later.
The idea here is to use the second seal as a "dust excluder" (a misnomer since what we're hoping to exclude is mud, rustbugs, water,sand, gravel, chupacabras, guapo, etc.).
If ya can source a double lip seal which is designed in the same manner, then it could certainly be used also! Since t's business is bearings, seals, and all the related guapo what goes with that, he's the repository of all the knowledge base for shit like this so I bet he can find us an even better system for this application. But...what we got here will last his lifetime (but maybe not jen's!).
And to make this all relevant to a Scout II transfer case setup, this is exactly the same type seal system that is used in the output shaft/transfer case adapter behind those "special" output shaft bearings that terry manufacturers exclusively for ihon!
Here's the completed second seal installation, this seal is knocked in until the edge of the case is just flush with the outer edge of it's counterbore.
Now, I've stuck the repaired coupling into the seal interface and pushed into approximate position of where the coupling will be located within the seal system. Ya can see the end of the repair sleeve protruding from the seal lip and shows we got plenty of engagement of the seal lip and sleeve...just right!
So there is no need to "adjust" the position of the two seals, now this retainer is ready for re-installation. Lucked out here, this has nothing to do with skill! Skill means ya always source multiples of any part like these seals so that when ya fuck up the first set, ya gotta another set to use after yore learning experience. Or in my case, I set 'em down somewhere and kain't find 'em until next month and they show up like majik in the refrigerator or beer cooler.
Now let's do the rear output retainer seal install.
In this case, the replacement seal is a kinda "double lip" version that has an hd lip for keeping lube in, and a hd lip for keeping mung out. So no need to do the double-up deal here! And...the front output and rear output seals are different in size, they don't interchange on this particular 205 case, but on some versions they May.
So this is a straightahead, knock in the seal until it bottoms in it's counterbore kinda deal.
