Robert Kenney
Super Moderator
Yep! That is the one and the scroll housing is reused.
great info. I'll tear into the water pump tonight.
Can you give a more specific link to the "paint" you are using? I can't seem to find it. Is it good for high temps on the block, etc.?
What coating do you like for the exhaust manifold?
If you want a grey, how about lycoming gray.![]()
I had the bumpy shaped extra compression pistons, and the new ones will be like that. He said he found flat tops too, but the compression is only 8:1 or so with those.
the "bumpy shaped" pistons are also known as the "special contour design", or "non-e", they net the same cr when used with their corresponding head. To switch to the "flat top" piston you would need to switch to it's corresponding head.
8.0-1 for both setups.
A note on the pistons. Only one piston mfg retains the stock height so you will retain your compression ratio. Those are silvo-lite. All others from what I have seen are decompressed .020 so you will net a lower cr.
Also due to the fact that your engine's c-ratio is based on the original steel head gasket, when you use the available composite gasket that has a compressed thickness of .040 you need to remove .020 from the deck to retain the already low 8-1.
This is easy for your machine shop and they should be cleaning the deck surface anyway.
