There should be some small set screws that hold it in place. Yep, hopefully the one you need is the cheaper of the two, but still not chump change. I'm sure you could find a presto module test procedure on the webs if you searched. It would probably make for another nice learning opportunity for you. I'm not going to attempt the search and walk you through it. Totally up to you if you want to pursue that step on your own. To my thinking, I'm fairly satisfied at this point after everything else you've tried, that a failed module is the primary reason why your engine dies and will only restart after a cool down period. Those are pretty telling symptoms, but I wanted you to perform some due dilligence before we rushed to that expensive conclusion. If you wanted to try exchanging your high dollar coil for a plain stock replacement as a last ditch, you could, but I don't think that would make any difference.
