R-100 4X4
Lets cut some holes ..
These Buick side marker reflectors will be fitted with LED lights ..
Got some work to do in order to make this look good ..
Was thinking about doing a chrome powdercoat on them ..
But, being the bumpers and running boards are gloss back, they may look better shot with black powder ??
Whatcha think Guys ??
The LED's are super bright ... Not sure if reflection would matter a great deal ??
They should show up tomorrow, I'll wire them up for a test ..
My neighbor allowed me to make a templet from his 48 Buick ...
Shot it with black powder, wanted to see how the chrome powder would look ?
Like the chrome better ...
Still waiting for the lights to show up ..
Trying to find a set that have good chrome ..
Fake chrome is close but no cigar !
.080" oversize is a bit much especially when the block was std bore to start off with ..
The way I got it figured, if you're not living on the edge you're taking up too much room !
This block is a 1990 Mark IV ( Last year for the Mark IV's ) out of a truck ... No core shift, I know it's not wise to go that much oversize, but I'm after BIG cubes ...
( That reminds me to charge up my Mojo )
There is a spacer ring that bridges the open gap to support the oil ring ..
Some wild engineering went down to allow a stroker crank to be used in a standard deck height big block ..
Did think about building a high deck block, but the dollar amount was going to be up there ..
I still have a 2003 Gen VII in the shop that I thought about building for the Binder ... It's 496 cubes from the factory .. Reason I'm not building it is, it's too new. Last of the Big Blocks from GM ..
The Mark IV'S been around since 1965 and was better suited for a old truck ...
Lot more goodies on the market for them than the Gen VII's ...
BTW ... Lookie what followed me home the other day ...
3-71 Blower ... Have no clue what I'll use it for, to small for the motor I'm building ...
Bout the right size for a flathead Ford V-8 ..
Guess I'll sell it for a few C notes ..
Motor work is going well ..
Bore notching should help those oversize valves breath better ...
Honing is slow go doing it by hand ...
Going with 100 grit stones to .002" of final size ... once I get there I'll change the stones to 280 grit and hone to .0005" of finish size ... That last .0005" will be honed out using 400 grit stones ..
Not done with honing the bores just yet .
Got the Plateau honing to do ..
Plateau honing is an advanced cylinder wall finishing process that creates a surface with smooth, flat "plateaus" on top for low-friction piston ring contact, while retaining deep "valleys" underneath for oil retention, improving engine sealing, reducing friction, shortening break-in, and increasing engine life by removing jagged peaks and torn metal from the initial bore. It's achieved using fine abrasive brushes or stones after coarse honing to level the peaks without eliminating the essential oil-holding troughs.
Very close to having the 496" stroker ready for the run stand to break-in ..
My poor old Binder hasn't seen much love here lately, been busy working on other stuff ..
Although did get a stroker crank ordered for the 500 ci motor I'm in progress of building for it ..
Still needing a few other parts to complete the heads, think I got all for the lower-end ..
Crank came in ..
4340 Forged Steel ..
A lot of forged parts going in the 500 ci motor ..
Been looking for a neat badge to go on the tailgate ..
Thought about doing a 4X4 emblem from a Jeep ??
Wanted it to be made in the 40's or 50's and reflect what the truck is ..
Found a emblem that fits the build .. Doesn't say 4X4, do have that going on already on the hood ..
Since the truck has a V-8 and overdrive this was the perfect choice ..
Was watching a Jay Leno video of one of his cars and there it was ..
Thanks Jay ....
Both blocks are the last year for the Mark IV big block Chevy. ( 1990 )
Both are strokers, the black one is sporting 496 cubes, the other is a little larger at 500 cubes ..
Motor work on the 500 ci BBC is on going ..
Doing a few checks just for peace of mind ..
Zero deflection on the forged steel crank ...
(Liked seeing that, or should say not seeing that)
Right at .004" end-play also is good to see ...
Cam and bearings are installed ..
Got some work to do fitting the crank scraper, doing a mockup with rods, pistons and crankshaft temporary installed ..
Once that work is done and over be time to balance the rotating assembly ..
Sure would like to internally balance the crank, but material to do so would dig deep into the pocket ..
