wmnan
I appoligise... 1-1/2turns is correct. I lookk at the keyboard when typing not the screen, because I'm just not that good of a typer.
I am tracking with all up to this point.
I will look around for a dwell tac. I read that dwell angle is critical in order to set the timing properly spceially with a rig of this age. And who knows what the po has done. I know I have had the rig for a while but this is the most I have done to it mechanically.
Initailly the rig was running rough. Once I got the float bowl filled it seamed to calm dowm, it is not idleing as smooth as before, it sounds like it is stumbling slightly, so I turned up the curb idle screw. It's not as smooth as the 51's but not bad. The setback is the 15hg of vaccume. :/
once I get the dwell meter I will let you know and we can go from there.
