Robert,
your post about referencing boost on that carb kind of stuck in my head. I won't do this, not at first, anyway, because this basic setup had a history of working. Not optimal (only efi is optimal), but reliable and "safe". So I am starting out very Rich and will go from there according to what afr readings come from a wide-band sensor.
Recapping the issue: you can be running half-throttle and pulling a good vacuum on the carb side, but the turbo is turning that vacuum into boost, and will run lean. The pv circuit isn't getting the right signal (assuming it would enrich enough even if it did). Running a line from the manifold side gives a proper signal to the pv, which then must be jetted properly to not only give proper enrichment during n/a running, but under boost as well.
Back to the yh. When vacuum goes away when you run, say, full throttle, assuming n/a only, then the rod needle is tapered so that full up the engine is enriched accordingly. But the rod needle can only go so far; with a turbo, when manifold pressure is tipping over into positive territory, that rod needle taper/jet combo cannot provide additional enrichment. Hence tapering the needle to run Rich enough under boost, but it will run over-Rich under a max throttle position and not generating boost.
I have a spare yh apart here and had a duh! Moment. The vacuum chamber that pulls down the rod is on the bottom of the bowl. It should be easy to simply drill and tap a tiny hole dead-center in the bottom of this chamber, which would then open to the outside, on the underside of the bowl. The passage feeding this chamber could be closed off with a teeny ball bearing or equivalent. Run that line to the manifold side. Would be ridiculously simple to do. Now, what would the advantage be? While the signal would reflect true operating conditions wrt rod position, I see the same problem in that full up, the needle needs to be the same diameter or taper in that area. I think any advantage would be in the step above that might be thicker and leaned out slightly? Again, as I'm perceiving this, the problem area is the transition zone at wot when manifold pressure goes to zero - not leaning out there. These are the physical limits of this particular configuration.
Is my logic right?
