To be clear, I think we are talking of two different conditions (I think). Regarding a draw-through, I get that. You can have a strong vacuum in the carb, and the pv circuit not activated, while making boost on the other side. Lean = boom! So the signal to the pv is moved to the downstream side of the compressor. Explained in mcginnis' book. The thing, then, is you have the right signal, but then need to richen accordingly. Now, I am talking about a blow-through. Here you go wot, but no boost - yet. Little or no vacuum, pv is activated. Now as the engine continues towards boost, the pv is contributing all it can already, and then you encounter lean unless you can richen things up past that point. Which means a pv that provides a certain level of additional richness up to 0 vacuum, but would somehow need to increase this when going to positive pressures.
Regarding the 1904 used on the 152t. It appears that they just used a bigger main jet and used the stock pv. The main covered the sins of leaness under boost. Probably terribly Rich when not under boost, or most likely, terrible all the time! But not leaning out and detonating into oblivion.
I am seriously considering blow-through using the stock Holley 1940 (not a 1904). It has a similar pintle that opens when vacuum drops, and fuel entering the pintle well flows to a small restrictor, a jet, really, that provides whatever richness the pv is supposed to provide. But while the pv won't provide added richness commensurate with positive pressures, you also won't have the draw-through situation of having a vacuum signal on one side and boost on the other. Just a lean-ness that grows in a linear fashion as manifold pressures go from negative to positive. Still a problem that needs a solution.
