rascal7298
Has the old iron pdf been updated to include photos?
the IH service manual contradicts itself on rocker arm shaft orientation. In the manual (cts-2130-k) page 34, figure 109 and para 7 says the notch should be oriented "up". Later on page 53, para 28, says the notch should be facing "down". Not sure why the discrepancy. I have the 9 stand, welded type and am planning to go with "up" orientation based on reading this thread. Any thoughts on why the manual lists conflicting guidance? Am I missing something?
great run down on the oil system and start up procedure . I have 345 ci 1110 pickup it has sitting in the woods for about 20 years. I started it up it ran well and then it promptly bent two push rods. I tore it down , rings bearings lifters and valves. It all looked good no metal on the ( babbitt) flakes did not touch the cam so far the lubrication system is doing what it is supposed to except the right bank lifters don't appear to be getting oil pressure. That is the right side sounds like it has badley adjusted solid lifters is it possible for the rocker to get oil and not the lifters. I did notice the pulsating feed to the rockers that works. Any suggestions???
Gordon
Robert today I received two new rocker shafts with the boat or cup type rockers these are different to mine (the welded kind) I assume they are interchangeable ??
