Nine stand rocker assembly with boat rockers, someone's been diddlin' in the sand box before you!
Classic case, there is no telling how these rocker systems May have been butched by the po virus in the past. I've even seen motors that had a mix of boat and welded rockers on the same shaft! No freakin' way that pos can oil!!!!
If it's a true nine stand rocker shaft (not a re-drilled five stand), it should have been flipped upside down so that boat rockers can oil.
We have reconditioned/inspected ball/ball pushrods for 152/266/304 on the shelf here at ihon (we refer to those as the "short" ones!). You won't see those in the online store, you need to call Jeff and order. If he's out-of-stock at his location, he'll call me and I'll drop-ship. I'm looking at a box of about 35 pieces right now!
There are two designs of the boat rocker ball/ball pushrods, depends upon who the vendor to IH was at the time. One type has a distinct "ball" on one end, the other end is a somewhat radiused tip. The other style has two "radiused" tips. Guess I need to update this thread with examples of all four designs, (two long styles and two short styles).
T's certainly possible that someone May have had customs made at some point or simply boneyarded wrong stuff! These oem pushrods do not oil through the center of the tube, the balls have no oil orifice like some other oem motors use. But oil ports would not hurt anything as long as the ball radius is correct along with the length.
When we run out of these reconditioned pushrods, we'll have a batch of new ones made by our manufacturer (not the same source as the oem stuff), that's not an issue though a significant quantity must be ordered all at the same time.
Let's see...you are now the fifth individual I've discussed this same thing (stuck valves due to non-lubrication) with since last Saturday! One was a 152, two are 304, the other two are 345. Only one of the motors had correct parts all the way through (the early 152), and it's issue was simply the rocker shaft was completely plugged closed throughout by sludge.
