Michael Mayben
you're saying 3.54 is a good gear ratio for 33-35" tires? That would be great if I don't have to do any gear changing! I already talked to Darren at ihonlynorth and he priced me up a set with all the bells and whistles... I just can't afford that much right now but I'm definitely inclined to find some way to do it, just to give them my support. Anyone have an axle you're looking to get rid of??? I'll post a quick thread in the wanted section.
I misunderstood, I thought you wanted to retain the 31" tires!
For much more serious trail use I'd run 4.56 or at the minimum 4.10. Either of those will involve changing both carriers in your existing axles as the 3.54 carriers won't work for those gears.
I don't have any axles available myself, but they are readily available here in the northwest (sii applications). Several members around here have swapped their sii d44 axles for other stuff out of their trail rigs and have a set already set up with the lower gears.
so maybe I'll be able to get this thing going this weekend after all.
