72 Ole Yeller
Oh yeah. That'll do it. Alternators definitely struggle and strain to replenish severely depleted batteries.
While slowly getting her to be road worthy, I decided to do a little breather/vent relocating. The bracket was a simpson strong tie angle bracket from home depot that I chucked up in an ole bridgeport at work, drilled and cut to fit the fittings that I purchased through egay.
Front axle, transmission, transfer case and trans adaper to TC are now breathing through the filters up on the firewall.for the 5th empty filter, eventually, I will route tubing for the rear axle.
I also purchased a new battery. No more need to jump start off my yota to get her started. Hopefully, within the next couple weeks, I will be able to start driving and enjoying ole yeller. Instead of staring at a huge door stopper
Well, finally, after months of procrastination, lack of funds and time, last Friday, I got her insured, registered and was able to legally drive her out of storage and take her home. Furthest I ever drove this since I owned it. Long story.
Handle exactly how I expected. Like crap. Typical scout wandering, along with a P.O. piss poor job of an install of a crappie tilt steering column. I'm kicking myself in the butt for not replacing the column when I had a chance, along with doing the shackle reversal install when I still had a shop space with power. I already have the reversal kit on the shelf. And went against my better judgement of wanting to see how it handled before I did the install:out::nono:
Be about a month before any new updates. But future plans of reinstalling the front bumper with a possibility of a winch, along with a dual battery install. So stay tuned:thumbsup:
Well, I somewhat retract my thought if driving like crap. Guess that I been getting a little spoiled with the creature comforts of my '02 yoda sequioa. Coupled with not driving my own scout in about 4 years.
It drives like an old truck. With the typical road manners of scout wander. I had a chance to drive it around town a couple times this week. I kind of surprised myself, that the 727 didn't puke all over the place. Since that trans was the first Chrysler transmission that I ever rebuilt on my own bench. Felt like I need to do some band adjustments, overall seemed to be okay. Although, trans temp seemed to be getting high at 190*. So I will be looking unto that as well. Currently have othdr obligations at the moment, so it will be a few weeks till I get to it.
Also, the non-stock tilt column will need to be replaced. Hopefully with a non-tilt version.
Now the fun begins. Dual rectifier and second (group 27) battery on hand. Getting ready to install the dual battery setup. I'm considering installing the 2nd battery in the bed between the passenger rear wheel well and the tailgate. Once things get mounted and installation of cables, I will post more photos and details.in the meantime, I need to order up a battery box and 1/0 cable. Just haven't calculated how much length of cable will be needed yet
Spent some time installing the battery box and battery isolator. Since my plan is to route 1/0 gauge cable from the inverter to the battery box at the tailgate, under the length of the cab, I mounted a pair of through bulkhead connectors next to the box.
Here's a shot of the group 27 battery that I will be using as my second battery, along with the DC to AC inverter that will be mounted near the box by the tailgate.
After driving Ole yeller around town the last few months, I got tired of not having a rearview mirror that normally gets glued onto the windshield. The original mirror had fallen off at some point before I acquired this rig.
As I was searching in my storage for something else, unrelated, I decided to take care of mounting this mirror, that I managed to salvage from my rolled scout. Surprisingly, the mirror didn't get crushed.
With the help of a friends driveway, and a few days of work, I finally took the time to install this shackle reversal kit that I have had on the shelf for the last 3 or 4 years.
What a difference. Handles much better now. Wish that I would have done this a few years ago. Procrastination got the better of me. Now, I can move onto other maintenance issues, like completely rebuilding both rear and front axles. More on that soon
Out with the old and in with the new. When I recently installed the shackle reversal kit, I noticed that the old front shocks were at least an inch toi short. I needed new shocks anyways. And since I had to return my old calipers in for core charge refund, I payed a visit to our friends at IHPA to apply the credit to these new shocks.
Now time for a drive
Teralow gears D-20 transfer case just installed. I had this Teralow gear built D-20 sitting on the shelf forabout 10 years or so for another project that I never got around to. I have been wanting to install it here for the last 5 years. But the bull gear that I had was for the manual transmission, but Ole Yeller has the 727 automatic. Two weeks ago, I scored a Teralow bull gear for the automatic.
The top two gears are the Teralow gears, manual and automatic. The bottom gear is the OEM bull gear.
When I built the transfer case, I modified the shifter rail for fully twin stick application. I, also, added the Advanced Adapters 32 spline upgrade output shaft in the rear.
Here are my home made shifters. Crude but effective.
The dbl cardian drive shaft next to the new OEM drive shaft20190901_125833.jpg
Last couple weeks, I managed to do some work on Ole Yeller. Two weeks ago I replaced all 6 bearings, along with new seals and thicker axle shaft mounting plates, for the rear axle. After crunching the numbers stamped on the ring & pinion gears, I have 3.54 gears in the rear. Also realized that I have what appears to be a trash crack lock that is falling apart. Pieces of metal chunks, that hold the clutch pack, was falling out. Not to worried about it just yet, because with my spare rear D-44 housing, I am in the process of building it with an ARB and 4.10 gears.
Also:
11 months after I completed the Shackle reversal kit install, I finally ordered and installed a new front drive shaft last weekend. Turns out that my front axle has more issues than I expected. With my twin sticked transfer case, I shifted into front drive only and went no where. From what I can tell, the left, drivers side, locking hub was not engaging. Sigh, guess that going wheeling is on hold until I get to rebuilding the front axle too
Christmas came a few days early. Got myself a new air compressor, and a few other parts for my scout.
Spent a few days this past week installing it. Mounted the air manifold and hooked up the wiring.
Then I temporarily hooked up my old 2.5 gallon air tank to test the system. Plus, I needed to use it briefly.
I have two identical air tanks. And they both will be mounted under the rear bed, directly under the rear bench seat. Already drilled the holes. Just need to go get new stainless bolts and a second pair of hands to mount them under the bed, while I get someone to help screw in the bolts
My current project for Ole Yeller, is building up a pair of dana 44 axles. Both with ARB's and 4.11 gears. Since I had the spare front housing, and I did not want to do things twice, I had the C's cut-n-turned. I don't have the space, or the electrical requirements to do it myself, I ended up contracting IH Parts America to do it for me. Thank you Darren.
I will post up a few more photos within the next couple of weeks. My full time job is getting in the way
The rear axle is 80-90% complete. Was hoping to get the new brake shoes installed. But they didn't come with the E-brake lever to hook up the new E-brake cable. Speaking of which, the backing plates were so crusty and caked with rust, that I ended up having them powder coated.
The new axles shafts are 35 splines. A bit over kill. But, I have had this ARB, that I installed, sitting on the shelf, collecting dust, for a number of years, that was for another project. Got tired of letting it sit there. And it was cheaper to purchase new axle shafts, new bearings and seals, and thicker hold down plates. Also, since I'm rolling on 33" shoes, I went with 4.11 gears. Also, the 8 lock nuts, 4 on each side, that holds the axles and brake backing plates in place, where worn out and miss matched. So, I ended up installing new lock nuts when I installed the axle shafts.
You using the newer jeep carrier, ring and pinion? Like the Jana 44 kit?
For the front axle, I came close to getting that kit. Spent some time talking with Carl Janz about it. We both agreed that it would be over kill, since my tire size will most likely never get beyond 33". But to be on the safe side, I ordered the ARB carrier for the 3.73 down, along with the thick 4.11 ring & pinion. In case I decide to actually go with the Jana 44 kit in the future.
The rear is different. I purchased that ARB unit about 15 years ago, for a different rig, but never used it. When they came out with the 35 spline version for the Dana 44. At that time, the Janz kit wasn't available. And, at that time, I wasn't aware of being able to use thicker ring & pinion gears. In the mean time, I was tired of letting it sit on the shelf unused, collecting dust. Not only that, my current axles under my scout are in need of being rebuilt
The last couple days, I have been swapping axles into my scout. As of last night, this is the first time that I been able to have 4x4 capabilities in this thing, since I had her.
Also, within the last couple of weeks, I replaced the old tired carb and installed a Holley 2300 two barrel 350cfm. And replaced the whooped fuel filter and a portion of old fuel line.
The last 14 months, I been dealing with a leaky whooped radiator. Picked up a new one about a month or two ago from our friends up at IHPA, when I was up there last. I finally took the time today to install it.
While I had the old radiator out, I decided to replace the water pump too. Had plenty of room. Time to button everything up, fill with coolant and go for a drive
After I replaced the radiator last weekend, I ended up with a big electrical gremlin. Turns out to be mostly a grounding issue. And my alternator was acting up and not keeping up with the demand. With all the recent additions. My stock rebuilt 10si was becoming a week link. So, I just finished installing a CS144 alternator. Picked it up from the wrecking yard and then dropped it off to be rebuilt.
Almost bolted right in. Was able to use my original bolt going through the a/c bracket. But, the adjustment arm needed to be filed out to compensate for the larger bolt.
Here's something that I have been wanting to do for awhile. Since I have been able to drive this rig, up until recently, I haven't had seat belts.
About 3 or 4 weeks ago, I pulled out the stock roll bar out, drilled a couple holes through the tube, then went to my buddies shop and welded the threaded bungs into the tubes and then had the tubes powder coated. In sticking with the overall scheme of things, I obviously went with yellow
Back in February, when I replaced the alternator, and the last time I actually drove my scout, the transmission decided to piss all it's fluid out. Ran out of gas, 1/4 of the way home. While sitting there on the side street, waiting for a friend to help get gas, trans fluid was pouring down the passenger side frame rail, near where the trans bell housing bolts up to the block. Ever since, I was wondering what I did wrong, when I rebuilt it 4 years ago. But, luckily, I had a spare 727 transmission sitting in storage, and a few weeks ago, I dropped it off at a shop to be rebuilt. Didn't exactly trust my skill level at this point. Nor, do I have a clean space to actually do that kind of rebuilding. Two weeks ago, I swapped out the old and installed the new.
At one point during the day, I was sitting there on the tailgate, taking a break. And noticed something on the old transmission that didn't look right.
Thing was on crack. Still not sure how that happened. Possibly the servo got cockeyed somehow. At some point, when time permitting, I will put it up on the bench and see what exactly happened. Mostly out of curiosity. Since that housing is junk, I'm sure glad that I had a spare one on hand to work with
After 9 months of letting my poor scout be parked out on the street, I'm able to drive it again, for the most part. Still need to adjust the transmission shifter cable, along with a few other things
Finally getting around to replacing the drag link and tie rod. Both rod ends were whooped on the drag link and being all one piece, there's no ability for any adjustment on it. Plus, I wanted the ability to replace the rod ends without having to replace the entire drag link. So, I made up my own, using 1-1/4 DOM tubing cut to length and weld in threaded inserts.
The past few days have been busy, giving Ole Yeller some much needed love. Finally was able to drive in for a much needed alignment. Which was needed after completely rebuilding both axles 12 months ago. Then pulled the brake booster off to get rebuilt. Dropped the booster off and 24 hours later, it was ready for pickup up. The covid19 pandemic sure has slowed everything down since March 2020
The past couple weeks have been busy. Recently installed a new power steering pump. Ordered one for press on pulley, only to find out that my old pump had a bolt on style pulley. Couldn't find my spare whooped pump, at the time, as a core, so I resorted to purchasing a 6" pulley. Which worked, to a certain degree.
Then, during the week, I finally found my whooped spare pump, that actually had a 4.5" press on pulley. I pulled new pump off and started swapping pullies.
So much better. I now can turn my wheels while idling at a stop. Then, last weekend, I installed the X-cross brace.
After a week of driving around, to and from work, I'm happy with how it worked out. Seems to have stiffened up the frame. And not so much body rolling going around corners. Also, while I was crawling around on my back, installing the cross brace, I noticed that both my motor mounts were shot. A call upto IHPA and ordered up a pair of new rebuilt mounts. And today was the joy of replacement.
Both my old mounts next to one of the new mounts in the center. Slowly she's coming together nicely. Becoming more fun to drive around.
