Mastiff
8.0-1 for both setups.
A note on the pistons. Only one piston mfg retains the stock height so you will retain your compression ratio. Those are silvo-lite. All others from what I have seen are decompressed .020 so you will net a lower cr.
Also due to the fact that your engine's c-ratio is based on the original steel head gasket, when you use the available composite gasket that has a compressed thickness of .040 you need to remove .020 from the deck to retain the already low 8-1.
This is easy for your machine shop and they should be cleaning the deck surface anyway.
This is great to know. I called the guy at the shop to sensitize him to this. Thanks. Is there any non-radical way to get the compression up more? I had in my head that 9-10 was a good high-ish range for a street vehicle.
