Soft_Click
I’m working on getting my horn functioning and struggling to figure it out.
The way I understand the horn switch, the cap will close the circuit against the steering column / steel behind the switch assembly in the center.
Knowing that, I should have one wire to the horn switch assembly and the other to the metal behind, which contacts when I depress the cap.
I was able to ohm out the wire I marked in the photo to the nut that hold the steering wheel on. The other pink wire that’s disconnected I assume is the one that needs 12V coming in, but I should see no resistance between that disconnected pink and the new horn switch assembly.
maybe I assembled the new switch I got incorrectly? The old one had a very long bolt and the new one has a spring with copper pins on either end. It should work all the same I’d think?
Maybe there’s a break in the disconnected pink wire inside the steering column? I haven’t gone as far as taking the wheel off and getting behind it yet.
