71mtnscout
The fuel cell is now dry. With that being done I cleaned all the sand, dirt, and left over plastic shavings that was inside the tank. I also readjusted the float level so that it reads truer than it did and started designing the mounting system. I will make a frame that the top will bolt to out of 1.5" angle iron which will be welded to the frame behind the rear axle and will have 2 1" support straps going under the tank to the angle iron structure to help support the weight of the tank. I will be designing the filler assembly in the next few days along with a new fuel pickup......that's all for now.
