ihpartschad
IHPA General Manager
Yep, live by the sword die by the sword.
I'll keep throwin' shit at chunk as long as it takes for it ta stick. Then maybe I'll start on the rot repair.
I doubt you need anything for chunk, but the sheridan pick-n-pull just got in another '73 IH pickup About a week ago.
you might want to check with superscoutspecialists...
I recall (vaguely) a thread on binder planet a year or so ago about somebody making some... But, I cannot find the thread... To see if any were made
you will want to swing by my table at the Binder Bee swap meet....
I have the instructions and everything.....![]()
michael, I'm sure you're way ahead of me on this one, but I'll throw this out and see if it sticks.
I was having similar symptoms with my rig when I got it going. It too is 9.0-1, but the block was zero decked and a composite head gasket used (.041" compressed). Despite what Robert kenny said about quench, I still experienced more knock than I expected (no offense Robert. It sounds like your stuff runs fine!).
When it came time to smog it, I needed a functional egr, and lo and behold, the knock stopped when I got it hooked up. I went from 5 deg btdc to 12 at idle. By 3000 rpm, the Mark is off the scale so I can't say what my total is, but I'm running a mallory unilite w/ vacuum advance (a swap meet score many years ago). I guess I could pull the vacuum line and see what the centrifugal contributes. Or borrow someone's dial-back light.
Bottom line, this made a huge difference in driveability. A friend says this is actually cooling the intake charge (hard to believe...)
also, I too am against running an IH motor on anything higher than 87 octane. Just doesn't seem right. Which isn't to say I wouldn't, but I get your vibe.
Good luck. Hope you get it sorted.
I'll take it chris, put a hold on it!
The 6a is the only one I use, who needs the rev limiter guapo onna IH motor??
