Yeah, 72 ft/lbs is a fairly massive amount of wrench torque and seems nearly impossible to achieve in that area without approaching the point of breaking something. Inch pound torque wrenches are not that commonplace anymore, so when dealing with torque settings calling for in/lbs, your best bet usually is to convert that figure into ft/lbs. For example, 72 divided by 12 (inches in a foot) equals 6 pounds. So 72 in/lbs is equivalent to 6 ft/lbs. Of torque, which isn't all that much. When dealing with a brand new reverse band, the standard procedure calls for stretching the band by over-tightening it once (though certainly not to 72 ft/lbs), then backing off the screw several turns before torquing it to the 6 ft/lb spec and backing off two full turns.
I suggest you shine a bright light up into the cradle area where the rear band rests and try to verify that both band anchors are still attached to the band. You'll probably only be able to see one anchor easily, which will be the outer one that engages the apply strut to the intermediate apply lever. Just verify that applying tension to the band via the screw and/or apply mechanism tightens the band to the drum. With the band completely loose, you should be able to rotate the drum freely by hand in a clockwise direction only. With band tension applied, the drum should not rotate at all. If that checks out good, re-torque your adjustment screw to 6 ft/lbs and back it off exactly two full turns from there. There will be a slight amount of play in the apply linkage at this point. The band has to be able to release fully when not in reverse or manual low positions.
