Scout II Ignition issues
sorry I didn't have time to look at all the pic.s,
No worries, I did not look at them either. Why? It's a pain to click on each one.
Kaipederson, you can edit your post and link the pic's so we can see them without having to click on them, by using the inset image icon. It allows you to paste a link to an image and we can then see them without having to click on them.
Alright voltage readings, battery-12.85 volts, coil negative terminal (with battery on)-11.37 volts, coil positive terminal (while cranking)-4.7 volts, coil negative terminal (while cranking)-8.49 volts. So from my test results I'm seeing the voltages drop when I crank the engine. Thanks for the info about the pertronix Craig and ron, and I did redo all those posts. Should've done that in the first place I didn't realize the headache those were, sorry. So with that kit what does it all include? And should I buy anything else with it?
Your current system has failed. There are no more sparks to be had from it. So yes, it needs to be replaced in some fashion with either a new gb module or pertronix. Resist the natural tendency to "upgrade" the coil with some blingy miracle-in-a-can capable of elevendybillion volt output. Your igntion system will only make use of what it needs, which is satisfactorily accomplished with a stock coil. If yours ever fails, simply replace with an inexpensive stock unit.
Either/or, not both. A new gb amplifier keeps everything stock. The pertronix kit negates the gold box. If it were my rig and my money, I'd go with the pertronix, but the choice is yours to make.
Removing/replacing the dist cap has nothing to do with whether or not the starter will engage. In fact, the distributor and ignition coil could be completely removed from the engine without preventing the starter motor from cranking over.
Consequently, voltage measured between the coil and distributor is meaningless when it comes to diagnosing problems with starter engagement.
The battery is your power source. Everything electrical begins there. It is the first item that should be status checked before attempting electrical diagnostics. Never assume that it is all good simply because the engine cranked over last week. That was then, this is now. By the way, do you have any idea how old your battery is?
Begin by measuring the surface charge with your dvom across the terminals and report your reading. As previously mentioned, the surface charge of a fully charged, good battery will register at or near 12.8 volts.
Next, trace the battery positive cable across the engine bay down to the starter solenoid on the opposite engine side. Ground your black probe to the frame or engine block and probe the large terminal lug on the solenoid with your red probe. Readout should be nearly identical to the one taken at the battery. What do you get?
Your readings at this point will indicate either a charged or a discharged battery. The next course of action depends on those results.
edit...now I see you deleted your previous post. What's up with that?
Thanks for the reply, I fixed the problem. I just noticed that the gearbox was shifted into drive. My fault I'm sorry. Thanks again though
I think your disconnected wire is the stock wire for the thermostat. It looks like you have another in its place now though.
Figured out how to use the timing light. How do you loosen the distributor to rotate it? Lots of frightening things happened while it was running not limited to flame in the carb jets, fuel being squirted out of the carb jets, and lots of loud banging. Not sure if that helps at all. Thanks
There is a bolt running through the hold down bracket at the base of the distributor where it penetrates the engine block. Loosen, but do not remove this bolt. That will allow you to rotate the distributor as necessary. All the symptoms you described indicate an engine that is way out of time. Since you have an inductive timing light, remember to time off cylinder #8 which is the rear most location on the passenger side bank. Do that to get it close and running fairly well. Then you can follow the power timing link mayben provided once you have it road worthy and ready for optimal fine tuning.
Got her all timed out and she runs pretty well now. Thanks for the replies. Only issue now is the carb just started leaking like crazy. Thinking about just buying a 2300.
Good deal. The carb behavior is completely predictable. There's no way a long neglected carb is ever going to function properly without first being completely disassembled, surgically sterilized, and then rebuilt with correct gaskets etc.
So now my question is, rebuild or buy a 2300? If I go with a 2300 where do I get one and will it need to be modified to fit? Thanks
