Don't splice the wire just for testing! Your probe should be sharp and pointy enough to penetrate through insulation of any wire to get a reading. The voltage down at the solenoid being the same as at the battery is a good thing.
If I understand you correctly, what you're saying is that there is no longer a bulkhead connector on the firewall, but rather individual wires running through the vacant hole? Is this correct?
