R-100 4X4
Clean up is going well .. Should come out of the cooker with all the grime gone ..
Here's a brief update on the 496" stroker motor I spun together a while back ...
Owner is making good progress ..
Richmond 5-speed looks right at home ...
This 62 C10 step-side is well on it's way to becoming a slick truck ..
Well ... Did a little boneyard scouting and found a remote reservoir power steering pump .. Already rebuilt a pump for the big block, going to pull it apart and change out the shell ..
Tis a little bit of backing up ..
Powder coat laid down nicely ...
Locating the reservoir up high will make for easy access .. Just need to find a hose that won't dissolve to run from the tank to the pump, and that modification will be done ...
Been busy with painting ..
Filled in a factory gap with weld and bondo ..
Shot epoxy primer ..
Real close to lading on the color ..
Did shoot color on the underside of the sun visor ..
2K Hot-Rod black should keep the glare down ..
The tinted windshield with a sunband built in should also help the cause ...
Well ...
Looks like I fell into doing up another PS pump for a friends body swap ..
He liked how my pump turned out that he asked me if I'd do his pump ..
I said 'Sure'
40 Ford 1 ton on a 99 C-30 frame sporting a 454" Rat with a 700R4 ...
Looking like it'll make a nice Rat Rod ...
Speaking of power steering I bought a cooler awhile back, getting around to mounting it ..
Best place is inside the frame rail next to the transmission ...
Should cool the fluid well enough ..
Parts came in to finish assembly of the heads ..
Soon to un-bage it ..
Going to internly balance the 500" motor, that move required a neutral balanced flexplate ..
I have a good Oem plate that has a weght welded on .. Was going to cut it off and use it, but decided to buy one instead .. This aftermarket plate is about .040" thicker than stock ..
Did get the power steering fluid cooler mounted inside the frame rail and plumbed ..
Wasn't all that fond of the barb fittings that it came with, changed those out to AN push-locks ... That makes easier to service when the time comes ...
Also got a inline filter to plumb in ..
Another item I wasn't fond of was the low pressure return hose that came in the hydroboost fitting & hose kit ..
Most likey it wouldn't cause a problem, but I ordered Evil Energy hose that is made for hyd. fluid ...
Way overkill, has a 250 # working pressure, the return only has about 20/30 # ...
