wmnan
Good day. I am having an issue with power. Where to start??
I have a 72 sii 304. It has points distro. Been having issues with rig starting and then shutting off after a short time. Battery was going dead so I got the 2 alts that I have tested both good. Lost all power inside the cab, so I took the daunting task of performing a continuity check on the entire interior wiring harness, some dirty conectors but all were good. Cleaned all connectors and re-installed. Turned the key and presto, it started, even ran for about half hour, shut it down cuz it was a long day. Next day went out it cranked real slow, then started. Took it down the driveway and it shut down. Turned the key and nothing. Played with the ig switch got it to start took it back up the house. Turn it off. Check for loos wires, found nothing. Tried to start it again, nothing. No power at all, no lights nutin.
Changed the ignition switch located on the column, no change.
Did a bunch of checks with the multimeter, noticed that the 1st 3 fuses have 12+volts with key off, as soon as I turn key on volt drops to 3ish on all 6 fuses.?? No clue where to go next?
