I'm a little confused as to why I have to still increase the pressure when most systems run 12.5 to 15 psi tops. I'm at 15 psi now and need to add more?
Not bad.
Could use a little more.
I was going to mention that an old school way to raise the pressure was to place a washer or quarter under the spring to act as a shim.
Went and got some plumbing washers that fit just right. I can add a little more before I drive tomorrow. I actually turned it down some during the logs because the Rich flag kept coming up. I'll order the 18 psi spring soon and then bug you about tuning a chip for me.
The Rich flag will always come on and off.
That's how the system works in closed loop.
It dithers the fuel mixture from Rich to lean so it can maintain the 14.7 afr.
Looks better.
I don't think you can do much more with some Rich and some lean areas.
You May want to bump the timing a few degrees at a time to see how it responds.if it pings, back it off a couple.
Can't tell if the tps matches the map tho.
You should turn the key on and open the throtttle and see if the tps increases from idle to wot without any dead spots.
There wasn't much extended wot runs just quick burst on the data.
