Bill USN-1
F.I. Moderator
Pm sent.
Thanks
Thanks
I'll take all you got chris, just let me know what I owe you and we'll even up, hopefully the weekend of the 12th I'll make it over that way. I appreciate all the help. Thanks
chris, chips and injectors installed. Started on the 1st crank. I'll be over the hill on sat. Give you a call before then to see if you'll be available, if not let me know where to stash your $ and where the springs will be.
I couldn't get any data logged last nite, stupid usb to serial cable still seems to not work. This is the second one I've gotten, starting to think it's me??
I bumped the fp up to 13 psi and ran some logs without the jumper installed. My alternator is only putting out 13.4 volts, I checked the connections and made sure the belts were tight. Looks like I'll be replacing it this next weekend. But until then here's the latest.
fuel is lean so bump the pressure a pound or 2 if you can.
Your charging system needs tweaked. It is at 12v at idle. make sure you check out madelectrical.com for tips.
