next silly question is then, does anyone have the correct chip for a 7747 v8 that they don't need?? Or can I just buy one somewhere? Thanks
the primary system being from a truck, van, or astro van with 4.3 or larger engines and using the 1227747 ECM. If you do get the 4.3 v-6 ECM, you will need to replace both chips in it with the v-8 chips. The v8 limphome/netres chip/calpack is marked 16060837. Order part number 16060836.
The v6 netres part number is 16051637.
The number on the chip that I had is 1 number different due to it being sold in the plastic carrier!!!
Use,
GM parts, GM parts online, Chevy parts, new GM parts
Or
GM auto parts at wholesale
Or
GM parts direct: your direct source for genuine GM parts
GM part # 16060836
category: emission control system hardware
pack qty: 1 core charge: $0.00
GM list: $21.07
our price: $10.54
description: calibrati
depends if your auto or manual.
5.0 or 5.7
I use asdu for the 345 auto.
But now I have to ask what your other parts are?
Where did the injectors come from? They need to match the chip and engine also or more tuning will be needed.
Don't forget you also need the netres chip.
You need to replace both chips under the cover when switching from v6 to v8 or the other way.
I found 5 different prom #'s to choose from on ebay with a quick glance, which one is best?
Akah
arjt
acsu
ancw
asdu
if you have the asdu chips I'll owe you big time!
I'm almost positive I have one of those. I 'think' that is what I ran my 304 with...
keep in mind he needs both chips not just the bin.
Edit:
just checked my mail and got a package from a guy with a 5.7 bin and netres chip that is looking for a 4.3 set.
So if you don't have both then these 2 guys can swap sets and you could send him a 5.0 chip to try.
I can send mls these 2 and he can send his to the other guy.
Color code d red/d blue
engine early bb pu
flow lbs/hr @ 13psi 90
TBI bore 51mm
GM part # 5235231 "
I have an asdu and a #16060837 chip ready to send out...
I also have a set of:
color code orange/black
engine 5.7l pu
flow lbs/hr @ 13psi 55
TBI bore 43mm
GM part # 5235206
if you want them you can 'buy' them too.... (unknown condition)
