Mark Pietz
Since I have my ic 196 four cylinder engine freshly rebuilt and actually running, I am setting about to convert the original ignition system, in this case a prestolite electronic unit, to a more modern crank-fire system.
First things first. I have done this same conversion in the past on a 1966 corvair corsa turbo I had. It solved a host of ignition issues regarding that particular application, and those same ignition issues certainly plagued the IH 152t turbo option as well. This setup will fix those problems, and I'll explain all that as I move along. I expect the same results here.
Second. This is ihon's board and the megajolt/edis setup isn't intended to compete with any products on this board. In fact, considering the intended goal of my project - turbocharging the four-banger - aside from efi, there are no products on the IH boards that adequately address the unique problems encountered. Neither the pertronix or the dui GM/IH hybrid distributor can advance ignition events under negative manifold pressure and retard ignition events when under boost conditions. That's the nut of it, and with that said, I'll move on to the conversion.
Very few old vehicles were supercharged, and those that were had ignition systems that were compromises, at best. The underlying problem is that spark must be retarded when under boost. Historically, this had been handled either by modifying a traditional vacuum canister to work in reverse (GM corvair spyder/corsa and IH 152t), and to forgo vacuum advance under normal cruise, non-turbo operation. Engines ran much hotter and mileage suffered as a result. No one made a vacuum canister that would operate under both conditions. To be technically correct, there were a few "smog" cannisters that could do this but were not manufactured for that purpose. They are generally unavailable now. I see now someone is selling modified GM vacuum canisters to work in both directions for the spyder/corsa application, but those aren't adaptable to our needs.
A few years ago some enterprising folks came up with a flash drive that acts as a substitute for the computer used to drive the edis ignition system used on 90s vintage fords. This system lends itself to being adapted to just about anything with pistons. Via a laptop, one creates their own ignition map and downloads it into the flash drive. I'm no computer wiz at all, and I got it to work. This is not as hard or daunting as it May seem. Plus, there are tons of 90s vintage fords in the wrecking yards and the basic components can be picked up for little money.
While the wiring and actual programming are the no-brainer parts of the conversion, the part that stops most people cold is adapting a 36-1 trigger wheel to the crankshaft. I got lucky on the corvair as I was at a metal scrap place and found some machined aluminum discs that were almost perfect for what I needed. I include some of those pics as a reference for creativity regarding what May be needed for an IH v8. Regarding the IH I-4, I think my approach is the simplest (and best!) way of doing this. The 304/345/392 May be a tougher nut to crack, as you need to deal with the harmonic balancer. There are aftermarket trigger wheels available in various diameters that I've seen and should be adaptable. The other is that you no longer need the distributor at all, but do need to drive the oil pump. I took a scrap distributor and cut it down. I'd leave the regular distributor in place, without wires, rather than waste a good distributor and cut it down. But there should be plenty of otherwise useless ones out there that can be repurposed this way.
This project can be approached without a particular sequence. As I was already rebuilding the 196, I chose to tackle how to mount the trigger wheel to the crankshaft pulley, first. That required also figuring out how to mount the pick-up sensor. Once that was done, I continued my build and eventually got it fired up. The trigger wheel and sensor are in place, awaiting my procuring the rest of the parts needed to bring it to completion. They do not interfere with the prestolite distributor and standard ignition coil.
Attached are pictures of the edis components you'll need. For my first setup, I went to ebay and bought a "kit" put together from salvaged parts. You typically get a trigger wheel, the ignition driver, and the coil pack, along with spark plug wiring, and harness plug ends for the coil pack, driver, and pick-up sensor. The parts pictured are for a six, and a four is just more of the same but with two fewer terminals, of course. For my Scout, I simply went to picnpull and grabbed these same parts from a 1993 Ford escort four-cylinder, but passed on the crankshaft trigger wheel, as I went in a different direction. I'll post those pics in the next post.
