Mark Pietz
Since putting all that stuff back on is going to be "down the road" a bit, I finished up converting it all back to stock today. I need it as a driver in the interim, and will do two oil changes in short order to flush out the aluminum fines from the turbo bearing that went south. As anyone who's owned a Scout knows, the stock exhaust systems are pure evil. The 196 has a crossover (well, cross-under) pipe going from right side to left side. Because removing anything at all for servicing or otherwise, once clamped, is horrible, today I put v-clamps on that head pipe just where it turns to go back on the left, and then the cat to the muffler. It can all be removed in short order when I need to swap it all back. I hate the two-bolt exhaust manifold.
One thing I plan on doing once it get it running is to get a baseline for performance, as in horsepower. I am going to either use the "dynolicious" app, or just go with marking off a quarter mile and using a formula I found that estimates hp from vehicle weight and elapsed time. The physics are actually quite simple, and nomograms exist from decades of drag racing. So I know that I weigh about 4,100 (with driver and full tank). I had to weigh it to title it last March. These numbers will be actual "wheel hp". I am thinking at this time that four popper should at least be doing 110 hp. With a turbo, I am hoping for 160 or so. We will see.
Tomorrow order the pieces for freshening up the turbo. I got an email from the guy that supplies some of my turbo specialty parts. He's looked at the f flow turbine in the one that "blew up" and says the journals will polish up nicely, plus the e wheel is still good. Even though I won't use these parts, it is good to know. I May hear from clark's in a few weeks if the original center section is salvageable.
Update: center section was salvageable and repaired. Always good to have a spare on hand, especially if it is made from unobtanium.
