Mark Pietz
My brain churned all night over this and I believe it finally spit out a potential cause for the failure.
I'm remembering that I had difficulty in sealing the 1/4" brake line that feeds oil comes from a 90 degree ell on the block by the oil filter. I had to make that flare four times before it wouldn't leak. So I made my first run and confirmed I was getting decent boost under some conditions. It began weeping again. So I really tightened it down. I am thinking that I crushed the flare and restricted the oil flow. That portion of the oil feed line is still intact as it was when it last ran. It will be a few days before I have the time to crank the engine over and see how much oil comes out of it. If it's pretty low, then I'm betting on that as the cause. Actually, I'm hoping it is, even though it means I was careless and screwed it up.
In any case, I have a lot of other very real distractions in my life right now and don't have the time or money to replace this turbo or go down the path of using a newer style. I was sooo close but have hit a wall.
I need the Scout to be a driver right now more than anything else. So my plan is to carefully remove all these pieces and box them up, for some future day, and put the original parts back. I'm hoping that a few oil changes will clear out the aluminum fines that resulted from the bearing failure. Hope I haven't done any real damage to the engine, but time will tell.
I'll report back after I test the oil line for flow.
I need the Scout to be a driver right now more than anything else. So my plan is to carefully remove all these pieces and box them up, for some future day, and put the original parts back. I'm hoping that a few oil changes will clear out the aluminum fines that resulted from the bearing failure. Hope I haven't done any real damage to the engine, but time will tell.I'll report back after I test the oil line for flow.
