Hi friends
I have a 289 mustang sitting as a garage sculpture for the ;ast 12 years. Many times I have had the engine running fine. This vehicle almost show condition. I did find that 2 gallons of gas in the tank over 12 years produced a bad black gunk in the tank.. I replaced the tank flushed the lines changed all filters and got the fuel back to the carburetor. It would not kick over.... So I removed the carburetor which is a Holley 450 cfm 4 bbl new but sitting. I flushed berryman chem cleaner thru the carb without removing the bowls. And some uncleanlyness came out. Skip ahead.... Then I removed both needles to check them which seem fine,. But now I cant find or get the float levels to work. I follow you tube videos and the best I can get, is priming the carb with injected gas .. About 1/4cup and the engine runs' ,, about 6 seconds healthy strong and high rev. It just runs down on gas is my thought and dies. I then go back to removing the site plug. Test the fuel level, rock the car to expel excess and the use a hypo dermidermic bbq needle to remove gas in the bowl. T hen dial down the needle and repeat the start / engine run to fill the bowl six seconds again. Repeating process and finally seem to find a good point for the level . But I cant get the engine to turnover on it s own/ just cranks the battery.
I don't think the needle is blocked since ......well I don't know that do I .? I have had the engine running on its own in this nightmare for about 60 second at a high idle and horrible roughness. This is a new carb and it seem clean and responsive I dont think the dirt in the tank really made it thru to the clear filters to be a problem. And I dont want to rebuilt it .
What have I missed.. It it possible to remove the carb to the mechanic so he can set the levels?
Lawrence
Lawrence
