scoutpappa
the electric choke system is not an "emissions" deal. It is a painless/troublefree (when adjusted correctly) carburetor circuit.
These aftermarket carbs when rigged with the electric choke make the starting drill (hot or cold) a no-brainer once the sequence is learned. Yawl are too young to remember carbureted vehicles when each model had a starting drill explained in the owner's manual. Hell, in texas...that was part of the driver's education curriculum (I taught driver's ed for several years), how to cold start a car and how to change a flat tire! But by the time I started teaching we had electric starters and did not have to learn how to hand crank.
The electric choke operation is an engineered, timed curve. Those do not meet any emissions criteria for any vehicle in any year model, these are completely for aftermarket conversions on performance applications. And even if an engine is "hot", it still benefits from having a choke partially actuated for restart. I deal with folks all the time that say..."it's hot here, I don't need a choke"...I tell 'em bullshit, every engine needs a choke if it's carbureted. Ambient air or engine temperature have nothing to do with starting an engine or providing a proper air/fuel ratio as the engine goes through warm-up. And an electronic fuel injected engine is no different, the a/f ratio is constantly being tweeked by the computer based upon sensor inputs from many sources as the engine goes from cold to normal operating temp,...thousands of times per minute.
Mechanical fuel injection with no dam computer...same thing based upon temperatures, etc. As throttle air bypass is temperature controlled, that acts like a "controlled" air leak on those systems. It works continuously, hot or cold engine temp/ambient air temp.
I am constantly learning something from you. I think I have the choke circuit set. Set the high idle and have a good switched source so tomorrow morning my wife and I will fire it up cold. It's 70 here and going to be quite a while before the block gets cold so I can show her a true cold start and after that we can practice with the warm starts.
