scoutpappa
For today. Got the new old cargo light in and wired. Just need to find some door pin switches and see if I can get the light switch cleaned up. Intermittant with making ground. So on to the really important problem.
I tried the choke again. Never opened up so I'm thinking soemthing is up. Need to figure that one out. Need some advice.
Also the carb has drifted maybe. I let it warm up with letting the choke work. So what I noticed and what my wife had commented is the idle went down. I checked it with the meter and it went down to about 630 at idle at warm. This is after I had to turn the choke "off". So what I am thinkig is maybe a vacuum leak. But after I set it again it stayed at 750 at idle at warm. Even with the idle so far down the truck runs fine and even in gear it idles well at such a low idle speed. Any thoughts?
