Michael Mayben
I use a high quality long-pattern tee handle hex wrench to access those set screws. Also sometimes I use a hex wrench socket that has had the bit cut down so I can fit a breaker bar in there to break the screw loose.
If someone has been into the case before, they May have used loctite on the screw threads (common practice). If that is the case, you May need to use either a heat gun or a small propane torch and gently heat the boss where the screw threads into the fork in a very local manner to aid in breaking the loctite bond.
The only secret is having a high quality, tool steel hex wrench, not the typical chinee shit found at the discount house.
