Robert Kenney
Super Moderator
Yes after lining up the gears verify the intake lobe location.
well it can only be in one place! Can't it?![]()
ok, so let me get this clear first. Where do I want my cam?
Second, how are you making the keyway? Are you making them or just grinding down a side? Would that hold up? I have access to a machine shop.![]()
tip for doing this is lubricate seal surface with couple drips of assembly lube, place seal in location and push bottom half in a little. Use your thumb to press seal over the crankshaft. Tap in a little and use thumb to press seal over entire circumference of crankshaft. Finish tapping in. Seal is very tight and if you just try to tap in like normal the seal will not slide over crankshaft onto crankshaft and probably damage. By taking a little time to ensure seal is depressed with thumb over crankshaft with a little lube it slide right on. Hope someone finds this helpful!
