Scooter
Active member
One of the things that has been extremely annoying about this beast, is that one of the previous owners int it's life time, used 2inch pipe tube for the body lift spacers.
as if the ole worn out original body bushings were not worn out enough as it was, the tube spacers compounded the situation. Anyways, I finally took the time to go into work on my day off last week to use the lathe to machine out a few 1 inch spacers. Only had enough time to cut 5 pieces. Needless to say I need to go back into work on my day off to make a few more.
Here's what I have so far
Btw - the semi rusty one in the finished photo, is 3/4" piece that I made about 8 years ago for my 72. The ones I am making now are one inch thick
as if the ole worn out original body bushings were not worn out enough as it was, the tube spacers compounded the situation. Anyways, I finally took the time to go into work on my day off last week to use the lathe to machine out a few 1 inch spacers. Only had enough time to cut 5 pieces. Needless to say I need to go back into work on my day off to make a few more.Here's what I have so far
