Rusty Scout
I probably did not run this thing long enough. It sounded like maybe they were beginning to quiet. I don't know this is the first time I have done this with an IH.
I did some googling and found some info on a vette site regarding moral lifters:
they will be noisy for several minutes. When I put in the morels, rick morel told me they might clack for as long as 20 minutes depending on temp and how long it took for the grease to wash out.
I know apples and oranges but it May apply.
Also in the comp cams tech forums regarding proper break in they say:always remove inner valve springs from dual valve springs or use low load springs in place of higher load springs during break-in. In addition, comp cams® offers low-ratio break-in rocker arms to give you an additional measure of camshaft break-in protection.
Which I did not do either. Fail
