Michael Mayben
Someone "might" still have oem-type shim head gaskets for a 304 (or any other sv motor) but I certainly don't look for those! They can be very difficult to make "seal" (and must be retorqued also). Those are designed for new head/block surface interface, or head/block that has been resurfaced to a "factory" surface finish specification.
The tiny difference in compression ratio which might be calc'd through the use of the current tech composition head gaskets is negligible except for a motor that is being blueprinted and is a cost-no-object build.
And if the block is decked, and the heads shaved to "level", then that also changes the seating angle of the intake manifold. If the shim head gaskets were to be used, the intake would need to be angle cut also. With a typical head resurfacing just to clean up corrosion spots, the manifold does not need to be angle cut if the commonly-available composition head gaskets are used.
Many of the engine rebuild practices described in the ihc-published service references were certainly valid back in the day when dealership mechanics did engine builds and had all parts needed easily available from many sources.
But 30+ years later/today, gasket technology alone has taken enormous strides, even for these old beater motors, an example is the composition "permatorque" stuff used by fel-pro and other suppliers. Same for those mylar shim gaskets found in the oil pump rebuild kits. Same for the type of composite rubber/silicone/teflon used in the "o" rings and crankshaft seals. "cork" gaskets are no longer cork, but a rubber/cork composite material which is superior in every way to plain cork.
