345 vs 392IC
Thanks for the hint, will have to do that. Just dropped the intake off at the machine shop. Heavy SOB. Will have it back on Monday and I can make some progress on it. Cant wait to have her back on the road, at the same time I can repalce the trashed freeze plug.
I will be pulling the carb off to help make the intake a bit lighter, off the top of your head do you recall what size the intake bnolts are? The truck is at my MIL place and I wont have the tools, they are still at my place. Thanks guys you have been great far as support
Some of those intake bolts can be challenging to get proper torque applied in either direction. Don't put all your eggs in one basket from a wrench perspective. Bring an arsenal so that you have an assortment of sockets, short and deep, thin and thick wall plus different lengths of socket extensions as well as combination open/box end wrenches. You May have assorted brackets and other brick a brack in the way. Some of the bolts are super easy to get at, while others towards the rear of the engine can be a pain. You just need to be prepared for whatever.
One more thing. The intake bolts are different lengths based on the thickness of the casting around each given bolt hole. Thick holes get the longer bolts and thin holes get the short ones, so keep your bolts somewhat orgeenyzd so that you don't get square pegs going into round holes if you know what I mean.
Yes I do, I got a few of them off. Didnt come witht he right sockets/box. Got a few off, got carb off, carb adapter plate offthermostat housing off. I do have a few question on parts. Pics coming now.
For the carb is that a spread or squarebore?? And rest of parts what are they??? Sorry I didnt label them when I was taking them, I tried to get good pictures
Pic 1 is an Exhaust Gas Recirculation (EGR) valve. Its an emissions device.
Pic 2 shows a heater hose fitting with a bunged up hose barb. You can get a new one at a hardware store. Take the old one with you for easy comparison.
Pic 3 shows the temp gauge sender. The wire hanging loose just to the side of it attaches to the exposed stud.
Pic 4 is an aftermarket 4bbl carb adapter/spacer.
Pic 5 shows a spreadbore intake identified by the small primary and large secondary bores.
Can I rip out the EGR and "forget" to install it? Or do I need somthing to plug the hole?
I guess I should also ask, I do have a 345 under the hood right????
You need to install a block off plate if you choose to delete the valve. With the 4bbl intake it has to be either a 345 or 392. Most likely a 345.
Ah ok, any way to tell for SURE it is a 345 or a 392??? I am at the truck today, going to try and finish ripping the intake off.
Best way is the ID pad machined into the block on a surface near the fuel pump. It will probably be greased and slimed over so some scraping and brushing followed by good lighting and maybe a closeup snapped on your cell cam should reveal the stamped in numbers. Another identifier of the Improved Cooling 392 ('72 and later) is to see where the metal coolant tubes enter the front of the engine. If they go into the engine block, its a 392 IC. The tubes go into the cylinder heads on the other engines.
Few more update pics. Water pipes are leading to block, will try and get to casting info by fuel pump
Or pull valve cover and post up the head #. Also look under neath at the edge of head & exhaust manifold, also will be a # there, or even could be stamped V392.
Refer to photo for location of engine ID.
It's on the block, right side, under the #2 exhaust outlet.
LOOK IN THE RED CIRCED AREA.................
Her is my intake after it got cleaned up. Looks pretty good to me, and it looks like EGR was already plugged
Got my intake back from the shop. Here is the pics, will get more progress her soon.
ok guys i must be a speical form of stupid (ha ha ha) well i got the 392( i think) intake all cleaned up, painted and ready to drop onto the motor. Well i ran into a semi major issue, the block that has the water temp sending unit. wel its too large to fit into the new intake. enclosed is pic. maybe you can tell me were i can get the corect peice, or tell me were it needs to go??????
hope yall can help. i will get more pics if needed. i had more taken, but i forgot to hit "submit" here and lost them, :(
