Oof, been a good minute since my last project update, this might be a two or three part job. . . *INHALES*
Since the last update:
-upgraded from a barn to a tent closer to my work bench
-my trans was thrown into the blender
-my t-case came out of the blender
-my t-case went briefly back into the blender and came out with a disk e-brake kit
-I rebuilt the mounts for the t-case (while i was at it I rediscovered the oem source for the bushings, now available here:
https://www.ihpartsamerica.com/store/SL163387R1.html)
-I confirmed my axles are 1973 1210 open diffs
-I got a $#!÷ load of new parts
-I discovered evapo-rust
-I removed the fuel tank
-I replaced the rear axle drive yoke
-My Broke Brakes Broke more and don't Brake at all again
-I started a 4 wheel disc swap (working on experimenting with early 90s chevy k2500 front rotors and custom brackets)
-I got a second carb and rebuilt it
-detail planned fixes for the front axle spring mounting at the pumpkin
-detail planned fixes for drunk simulator
-planned new custom leaf springs with Bilstein 5100s
-working on reconstructive surgery to fix my goobered driver side door
-lots of research about cowl rot repair
-lots of research about everything else
-removed my exhaust I had made at the shop and found out how bad they were at exhaust.
-removed everything the shop did and set fire to it
-found out my transmission is a swap in (still t98)
-have a solid game plan going forward
-tore apart my busted 8k ramsey, made a game plan for it and found some parts for it
-maximum project bloat achieved
The transmission, t-case, and heater all have their own rebuild threads, as will other components as I pull them out and reinstall what I have out. Updates to those threads will come at a delayed progression to this, just for the sake of making the information there as complete start to finish as possible.
Stand by, more to follow, I just put the first rebuilt portions back into the frame.
