Caperodder
Thanks michael. I'm in parts accumulation mode. Yer dead on with my winter plans. Working on 4 projects simultaneously as parts are delivered and time allows.
Rear passenger side is sagging pretty low due to a rotted tailgate sill and center crossmember, not to mention cooked body mounts. So yes, the tank is the first thing to get out of the way.
The matchless is firing up on first kick now, but I'm under a lot of pressure from the uk matchless club, not to restore it. The "it's only original once" story. So fer now it stays as-is.
Thanks again!
Brett
Thanks again!
Brett
you would be amazed at how much dirt/dried mud I pulled out of the void between the inner skin and outer skin. It was up almost halfway between the two bolt holes on the right.
