Hello,
I'm trying to understand what's wrong with the transmission in my 1100c Travelall. If I set the idle normally, when I shift into drive or reverse, it jerks forward and stalls. I can raise the idle to around 1500 and it will stay running but act as though it's under a lot of load.
It almost feels like the torque converter is locking up at a very low rpm? I tried screwing the vacuum control unit out to reduce control pressure, not sure that worked honestly. Going to try to do fluid change, it's tight under there near that cross member.
Wondering if anyone else has experienced this? I'm new to Travelalls.
Thanks!
Dylan
Thanks!
Dylan
