Michael Mayben
I've recently been working with some "later" Scout II 727 slushboxes and now have an opportunity to document some areas that need special attention when making repairs or performing a complete overhaul. For the most part, this involves paying special attention to "parts" when using either good used components, or new components as replacement items.
Sometime in the late stages of the so-called "1977" production run on Scout II, the 727 was changed to an updated version. This was because chrysler designed the upgrades in order to bring the transmission apps in line with future emissions regs, and to be able to offer the infamous "lockup" torque converter system in their light duty vehicles. Thus the design changes trickled down into the IH and amc apps also.
When working with specifically the IH-version 727, you must have the part number for the trans being serviced handy in order to make certain any replacement parts, either new or donor/used are suitable. I'm gonna say one more time...the urban myth that has been perpetuated in these forums for many years regarding "the 727 transmissions in IH stuff are all the same" is total bs! End of story! Generalizations regarding components such as this will eat your lunch at some point!
This is also true when working with chrysler 727 apps as they used many variations over time. And yes...many components interchange between IH, amc, and chrysler variations...and many do not!
The first part I'm gonna discuss is the valve body. In other threads in this sub-forum you will find pics and descriptions of the "full throttle kickdown" valve body that was used in all pickalls and Scout II 727 apps up through sometime in the '77 sii production run.
This pic shows a "partial throttle kickdown" valve body as used in a 1978 Scout II with an sv motor. Several reasons for the change to this design...but the major one was "emissions" and to prepare the valve body to be used with the lockup torque converter system which thank goodness...IH never embraced on the Scout II!
This valve body is identified as having the add-on module mounted to the earlier design valve body. There were also some internal valving mods incorporated into this valve body, part of the continuing evolution of this transmission as the automotive industry changed.
When using the IH parts list for the Scout II platform, you will see many references to vehicle serial number and transmission assembly part number made for identification of parts. This information is critical when dealing with these transmissions! Nowhere in the IH parts lists or service manuals are these subtle "changes" discussed and described! You just have to figgr it out! Information such as serial number cuts and component changes were covered in individual service letters to the dealer and we generally don't have access to those.
Next question...does the part throttle kick valve body backfit correctly on an earlier 727??? I don't know! I'm fairly confident it will and will allow the trans to operate correctly...but until I can personally try that and test that combo, I will say no!
I'm working now with a p/n 492448 c91 trans (m/y '78 trans, but m/y '76 vehicle which means this tranny was swapped in at some point in time and is not original to the vehicle...sound familiar?) that worked perfectly after trans overhaul by a pro for 16k miles. It was later damaged during an engine r&r and subsequently had the pump replaced with a unit from an unknown source tranny. Once it was re-installed and tested, it had no forward drive but did have reverse.
The problem??? The used replacement pump that was installed will not provide pressure to the rear clutch so that the vehicle will launch in breakaway. The oil porting is not compatible by a long shot!
We'll look at that next!
