Btw...I posted this on the other IH sites, because I am desperate! So......
Of course, this always happens when you have a big trip planned..
My '72 Scout II with 345 and a/t will intermittently not start. You can hear the starter relay clicking away under the dash...I pulled it out and I can feel the clicking inside. Also sometimes there isn't a clicking sound at the relay and the engine still won't turn over.
The lead at the starter is tight so it feels like there is a good connection...
Then for no reason whatsoever....it will finally turnover after trying (and swearing).
When I can get it to turn over then....
The battery is fully charged and the alt is charging....there is 12v + at the starter when ignition is on and there is a drop when I can get it to turn over.....then when the engine is running it comes back up.
Is it possible that the neutral safety switch comes into play here too? It's hard to replicate the problem in front of my mechanic and what to try to sort this out before my trip in a few days and have to rent a car.
Thanks all,
eric
Thanks all,
eric
