Rusty Scout
In the last few days there has been a knocking under the truck when its warmed up driven and parked for a few minutes. Does not make noise when warming up under high idle though and only makes the noise in park. My first diagnosis was there was an exhaust pipe hitting the frame. I had a pipe readjusted today that was close but not touching. No change in noise.
This trans has less than 1500 miles on it. Has a rebuilt sax-r14 converter, k225d-r rebuild kit, k22908b transgo noyoyo tf6/t-n and bushing kit k22902. Kind of a bummer that I asked for a tf-2 kit and now find it is some other number.
Today I brought it home after driving shut it off for a few and then fired it up. I crawled underneath and the noise was emanating from the bellhousing. Sounds like the tool elf is inside the torque converter banging intermittantly to get out with a hammer. Only in park. Noise goes away when put in neutral or in gear. Trans makes no noise when cold at high idle in park. Only when in park hot. If I had to guess I would say the torque converter is the culprit. Second choice is the trans oil pump.
Ever heard of this or is this a new one?
Also in the last few weeks there is a metallic chirp during the 1-2 and the 2-3 shift under load say like getting on the freeway from a stoplight. This condition began just before the banging noise from the bellhousing and continues. It also refuses to go into low above 25mph which I beleive should not be the case with the tf2 installed correctly
(edit)
now this is getting my blood pressure up cuz I am now seeing that someone May have dropped the ball besides me
little searching on the trango site shows the kit # k22908-b is crossreffed with transgo sk tfod-jr ( tfod-jr t22176 t22167 k22908nd k22908b k22946g 5005170an k22908njr)
http://www.transgo.com/crossreference.htm
And then further
sk®tfod-jr is for the following
88-07 tfod
42,42,44,46,47,48
re & rh
500,518,618
corrects/prevents/reduces: lube shortage;
soft shifts; kills engine in reverse; drainback.
Fits models with/without electronic governor system.
http://www.transgo.com/sk_dodge.php
(edit)
And then further
88-07 tfod
42,42,44,46,47,48
re & rh
500,518,618
