R-100 4X4
Fired up the 496" stroker today ...
Didn't run it very long .. Pulled the exhaust to be able to work on the starter support bracket ...
Changing out the dist. for one that works, got a new Accel on the way ..
Starter support is nailed on ...
Got a new Accel dist. coming in Tuesday ...
New project on the table ..
Building up a 4-speed trans from bare case .. This will be fun and very time consuming !!
I got plenty on my plate to get done ..
The heads for the 500 ci motor needs to be finished ...
Firewall needs to be painted ...
496" stroker motor sounds really healthy, got a lumpy idle to it ..
Did the break-in time, now it's time to build a shipping crate ...
Going to the 'Show Me' state ...
It's going to find a home in a 62 C10 stepside ....
Like this one ..
Got a feeling it will be hard to keep tires on it ...
The owner is doing a super slick job of building a Street Rod ..
... BYW ...
He did start off with a POS ...
Might say ... "Rough as a Corncob"
Another wild hair bit me ..
The 75 GMC K15 has vacuum boosted brakes on it, which is oem, they are working ready good and has been since 75 ..
Got a new ballgame with the big block going in it ... Might not have enough vacuum at low rpm's for the brakes to work proper !!
Found a 1999 C30 with Hydroboost on it, got the whole system off of it ... Power steering pump, brake pedal, lines and the unit ..
Changing out the M/C to one that has a 1.125" bore .. Be a better match to the K15 existing brake system, the C30's has a 1.250" bore M/C ..
We'll see how it goes .. ( Or in this case how it stops )
Slowly I'm nailing down all the parts it's going to take to do this swap over to hydroboost ..
Got the 1.125 bore M/C, the Wilwood valve and mount so far ..
The hydroboost mounting plate should show up tomorrow ..
Was going to make one, but these boys already had it made ..
Looks like I got a little more work to do on the wall .. The plate must sit flush .. Also those two top holes will be welded up, they was for the vacuum booster mount ...
Next to come up with is some 3/16" brake line ..Going with Ni-Copp ..
Need to run 2 lines from the Wilwood valve down to the oem proportioning valve which is mounted on the frame's crossmember ..
Made up a line to the valve, was somewhat of a job cause of the line being made of SS ...
Coming up with the fittings was another job, I'm using 1/4" line ... The valve came with fittings for 3/16" line ...
Making small progress, hydroboost pin was too long some lathe work took care of that problem .... Got a new problem with a pedal apply shaft not being long enough and eyelet hole to big .l
Think i got the brake rod figured out .. Just need to cut 3/8 X 24 threads where the yellow tape is at ..
Marrying a 1999 C30 hydroboost to a 1975 K15 pedal been a head scratcher !!
Believe I've nailed it ...
Had to relocate the pedal arm pin .750" to attain a better pushrod angle ...
Above photo shows the heim joint cut down bout a 1/4" ... I did that for the brake pedal height ...The jam nut next to the heim joint also needs to go ..
That move got the pedal height in the ballpark ... There is some adjustability that can be done to the pushrod if need be ... Also if I over shot it can go to that longer coupler ... Won't know till it's mounted in the truck ?
Got a little work to do on the firewall before it can be mounted ... The special mounting plate must sit flat on the wall ...
And those two two top holes will be filled in with weld, they was for the old 75 K15 vacuum booster bracelet which is not used with the hydroboost ...
Some thought went toward a power steering cooler, since more demands on on the pump now and will be working harder I got this to install ..
Might be able to install it inside the frame rail ... I'll find someplace to stick it ? ... ( No, it won't fit there )
Moving right along with the install .
Got the plate sitting flush on the wall .. Will be doing some test fitting ...
That's a different look ..
Got a special 4 point socket on the way. hoping that once it's tighten down on the plate it will be more level ..
That nut sees 110 foot pounds of torque, really didn't want to spend the money for it, but did want to see the nut put on the number .. !
Tried to use a wrench, didn't have the room for the swing ..
So I bit the bullet ... After all, stopping is just important as going ...
I'm wanting to do a nice job of running the hyd lines, they need to be universal so they will follow the frame rail then up the firewall ..
You Boys have any suggestions on a kit to buy ??
Much Thanks in advance ..
Well, I took the Bull by the Horns and ordered this kit ..
(Made in China)
The hydroboost will be flip over so the lines will be at the bottom ..
Dang nice socket, did it's job ...
110 fps with a drop of blue Loctite then the oem snap ring ..
Put the lines on the bottom for a bit better look ..
This part of the doing has been somewhat of a chore, it's not over yet still got the brake lines to run ..
Think I'll do them in SS ..
Made up a gasket, might help with keeping water out of the cab ..
Had a need to buy a hole punch set in order to make the gasket ..
Got a really nice set off of Amazon ..
Cool ... 1/4 SS brake line came in, this will allow me to make up my own custom lines ...
The hydroboost hyd. lines also was here, but I wasn't so they are still on the Opps truck ..
Tomorrow is another day .. :icon_razz:
Jumped too with installing them ..
Little rain slowed me down a tad .. But did make good progress ..
Jet washer cleaned it up good ..
Got the holes welded up ..
Ordered some satin black powder from Eastwood to shoot the pump cover ..
And hunting a rebuild kit to refresh the pump, since it's all apart be a good time to get new rubber put in ...
Found a kit, waiting for the powder ..
Kitted the pump .. Also changing out the fittings on the hydroboost to banjos ...
Pump is back together .. I had a # 3 flow control valve on another pump that I'm using should be enough GPM to do the job ..
Pump got all new rubber and wet painted, the tin is ready to be powder coated satin black ..
Soon to have it back together ...
Say Fellows ... Got 15 pages of this 'on going' build and not even close to sticking a key in it yet, just wondering if this thread is becoming boring to you'll yet ?
"Been four years on it this time around"
Good enough to keep it from rusting ..
Just about done with having the hydroboost really to bolt on the firewall ...
All work to make it work has been done,
Decided to use the fittings that came in the line kit, would love to have the banjos but due to the cost of those bad-boys I'm going pass ..
Well, I figured I didn't have enough to do ...
Soon I'll be laying down some color on the firewall and dash .. Truck came from IH with gaps between the A pillar and dash ...
Being I'm painting the dash anyways the thought was to get rid of them ...
Filled in with weld ..
And some mud ...
Well, another 454 found it's way to the shop ... This one has a K-case 400 THM trans bolted on ....
Pulled the oil pan to take a look at the mains, was wanting to see if it was a 4-bolt ... It was !
Got it to flip, kinda 'Big Block Poor' with the one I'm building for the 54 R 100 ...
Bored & Stroked to 500 ci ...
And got a 88 low mile 2-bolt from a Motorhome sitting that's never been apart in a corner of the shop .. Did replace the heads with a set from a Gen V ... That move was done for bumping up the compression a tad and better flow .. It's for sale ..
Now that I know this new to me 454 is a 4-bolt main block, don't want to flip it ... Might keep it to build and stick it in something ...
Doing a complete tear down on it, think it's still at STD bore, got a cast iron crank in it, will be run though the jet spay and then I'll be able to get a good look ..
Sure would be great to stuff it in this 55 Panel ...
(Don't really need another project, be for my son)
Got it torn down ...
Shoot, all it needed was a new set of rings, crank is still std on rods & mains, std bore ... Don't find them in this good of shape everyday !
I really want to keep this one to do a future build ...
