Hmm. Ok. Are you looking at the list 0-7448 as a replacement? You really don't want the 4412. It will make things worse for you.
but here's an update...last night we saw that the choke was loose said:If you look at the throttle 'rod' where it connects to the pedal linkage, there should be a clevis to adjust the length of the throttle rod to the carb. Maybe like 1/2" of adjustment is available from the available threads of the rod. You could replace the stopper bolt under the throttle so as not to damage the little nylon/plastic sleeve in the throttle pedal.
If you have upped the timing to +11 or 12, without the engine 'pinging', maybe the mechanical advance in the dist is restricted? Have you checked the mechanical advance with a timing light? How much advance are you getting? Reset the timing to '0' for this test - makes it easier to read the flash at the scale. Which # vacuum advance is in the distributor? Did you change the sparkplugs to the 'extended tip' with maybe a 40/1000 gap?
