Michael Mayben
In order to pull the bell, all the clutch guts and flywheel have to be dropped out the bottom!!! What a bitch it is to work with these power units!
Since these rigs have a "greasable" throwout bearing, someone has done one hell of a job of greasing it! There's gotta be a 50 year supply thrown all over the inside of the bell and covering the clutch assembly!
Once the brake pedal, cross shaft supports, and throwout cross shaft was pulled out, then the throwout bearing can drop free (pita #1).
Then from underneath (whole rotating the crank), ya pop the clutch cover bolts out of the flywheel (pita #2).
Hopefully the clutch cover and disk didn't take too big a chunk out of the shop floor, what a nasty/slimee clutch it is! Can't believe it actually held as well as it did! Pressure plate looks good, the clutch disc will go over to friction materials for a re-face.
Then the flywheel (retained by nuts threaded onto bolts inserted from the rear of the crank flange) came down. Two of the bolts are tapered shanks that mate with tapered holes in the flywheel for alignment purposes. The flywheel drops out the bottom also, pita #3.
Once the flywheel is off, the "wrap-around" bell housing can be removed and set aside.
Motor's hangin' on it's engine stand now for dissection.
