Dave Clifton
Well, finally got my griffin re-welded and now no leaks. Yeah!
First test run with the shimmed oil pump results are in!!
Original test run:
oil pressure (psi):
cold start-up:
1000 rpm = 40 2000 rpm = 45 3000 rpm = 50 4000 rpm = 50
hot (195°f thermostat open after 20 min drive)
700 rpm = 10 1000 rpm = 15 2000 rpm = 30 3000 rpm = 43 4000 rpm = 45
Today's test run with shimmed pump and previous oil and filter:
oil pressure (psi):
cold start-up:
1000 rpm = 53 2000 rpm = 57 3000 rpm = 60 4000 rpm = 60
700 rpm = 10 1000 rpm = 15 2000 rpm = 30 3000 rpm = 50 4000 rpm = 53
Results are exactly as predicted. Fantastic when everything works that way. I'm pleased with the results. Looks like when warm I'm getting 7~8 more psi. I think this provides a nice safety buffer when highway cruising. And I believe due to the thicker, cold oil I get get higher psi at cold start and warm up which should be a very good thing. I wanted to remain conservative with my alteration since my pressures were ok to begin with. I think if I had been able to start with a new spec spring (or maybe if I had tried to stretch mine back to spec) I might have achieved 10~12 psi.
In a week or two I'll change out the oil for the swepco 15w40, add a new napa gold 1452 filter and retest again.
Dave
Original test run:
oil pressure (psi):
cold start-up:
oil pressure (psi):
cold start-up:
Dave
